Eine 'noob' von UK
Xorro
Don Flocke
Grottenolm
QUOTE (Xorro @ 16 Aug 2004, 13:02 )The Alpine system I have is not designed to work with intercoolerthat's not completely true...if you change the intake manifold with a special one with an integrated aquacooler (no water injection) you can drive with much more psi than you do now...I thought about something like that...QUOTE my mechanic has said that lowering the compression (with a head spacer) may effect low-end powerevery time you lower your comression (it doesn't matter if you use a head spacer or low compression pistons) you will get less low end power and a bad throttle response...But with an aquacooling system you are able to drive at nearly 10-12 psi with your head spacer... which should completely eliminate your low end power power loss and give you a nice high end boost...
