resonator removal
Paler
hab hier grad eine DIY gefunden, die mich interesiert...nur leider versteh ich die nicht ganz...wäre jemand so lieb und übersetzt mir das? QUOTE (REDZMAN)Most of us have done this, quite a few of us as our first mod. If you have a CAI, you have definately done this.Well, here's a quick writeup on this easy, and FREE mod. Your car will sound nicer, will run cooler, have quicker throttle responce, and you will gain a bit of lost power back.If you've not done any mods, do this first.And NO, this will not harm your car or mess up your warranty in any way.Tools1. 10MM Socket, Ratchet, Extension2. Wire cutter (For cable ties)3. Clean towel/ragPhotoOkay, very simple folks, start out by opening your air cleaner box and removing your filter. Put it in a clean place.Then, remove the plastic pipe on the back of the air filter box, and pop the Air Temp Sensor out of the little hole. Put it on top of the spark Plug Cover for now.Remove the (I think) 3 bolts in the bottom of the air cleaner box and put that aside.Now, cut the cable ties that hold the battery cables to the air duct bracket.Remove all of the bolts that hold the Air Duct in place, and remove the air duct.Then, under the battery tray, remove the 2 bolts holding the resonator in place. Push the resonator out under the car (Easier than trying to take it out the top) and put it to the side.Using the clean towel, clean the inside of the Air Cleaner housing really well, and reinstall the bottom plate.Reinstall your filter, the air cleaner top, the rear hose going to the MAFS, and the Air Temp Sensor.You are done!If you are wanting even MORE power back, use the K&N drop in filter model # 33-2753.quelle: http://www.rdtiburon.com/forum/newreply ... eply&p=331
Tiburon2000
Nein die Filterbox kann drinn bleiben. Einfach den Schnorchel und den unteren Resonator rausschrauben, sodaß er direkt an der Filterbox ansaugt. Hab ich vor der CAI auch so gehabt. Das Ganze mach dann ein etwas tieferes und dumpfes Ansauggeräusch und bringt leistungsmäßig nix. (Zumindest isses mit G-Tech nicht wirklich meßbar)Wundert mich daß ihr das garnet kennt. Ist glaub ich des Älteste Mod, daß es fürn Beta-1 gibt... Is von der UK-Hyundai-Coupe-Seite und nennt sich "Snorkus-Mod". Das was der Ami da gepostet hat is ein offener Lufi mit einer Hitzeabschirmung und hat mit der "Snorkus-Mod" garnix zu tun...
DJ-Senser
Ameisenjäger
