Where to find Getz ECU/ which manufacturer?
Cameldiscovery
Hello Alien-w, ECU are located at the right A-pillar inside under cover. You have to remove the cover (two screws and one plastic nut). But before you can pull out these cover, you have to remove the top sill cover. Do not remove in cold condition (min. 20°C) otherwiese, the platic could be broken.To remove the ECU, be carefull, pin are fast bended and dmaged. With best regardsCameldiscovery
