Coupé Nachfolger?
[BILD]1195080325[/BILD] [BILD]1195080326[/BILD]Live-Blogging von der L.A. Auto Show:http://www.autoblog.com/2007/11/14/la-2 ... m-es/QUOTE 5:34 PM: CONFIRMED: Front-wheel-drive Tiburon replacement and rear-wheel-drive coupe are two different vehicles.5:35 PM: Showing video of RWD test mule all covered up being thrashed on the road. Now it's being chased by a photographer on a motorcycle. We're so confused here.5:36 PM: The sheet's pulled off. Pics are on their way, but we can tell you the vehicle is very tuner-oriented. Called the Concept Genesis Coupe. Bright orange paint and carbon fiber hood pop. Dropping beltline behind doors is a signature design feature. Carbon fiber-tipped spoiler sits out back while the front is capped by a carbon fiber fascia.5:38 PM: Engines will be a turbo four-cylinder and the 3.8L V6 from the Genesis sedan with over 300 HP. Brembo brakes and an LSD will be offered.5:39 PM: Production version will be shown at New York Auto Show in late March.5:42 PM: Hyundai reportedly used the BMW E46 M3 as a benchmark!QUOTE PRESS RELEASE:HYUNDAI UNVEILS REAR-WHEEL DRIVE CONCEPT GENESIS COUPELOS ANGELES, Nov. 14, 2007 – Hyundai unveiled its highly anticipated Concept Genesis Coupe during a press conference at the Los Angeles International Auto Show today. The concept car heralds the introduction of an all-new, rear-wheel drive 2 + 2 sports coupe scheduled to join the Hyundai lineup in the spring of 2009. Following the introduction earlier this year of the Concept Genesis sedan, Concept Genesis Coupe signals Hyundai's second step in broadening its appeal to driving enthusiasts.The Sonic Orange concept is complemented by a Ballistic Black carbon fiber hood, roof and ground effects for reduced weight. Strong hints of the production version are highlighted in its "Z" bodylines and powerful curves. When the production sports coupe arrives, it likely will be the most affordable 300+ horsepower car on the market, and the most dynamic performance car yet from Hyundai.QUOTE CONCEPT GENESIS COUPE SPECIFICATIONS· Configuration: Front engine, rear-wheel drive sports coupe· Wheelbase: 2,820 mm / 111 inches· Overall length: 4,666 mm / 183.7 inches· Overall width: 1,902 mm / 74.9 inches· Overall height: 1,386 mm / 54.5 inches· Wheels: 20-inch, five-spoke· Tires: Hankook 255/35 ZR front and 275/35 ZR rearPRELIMINARY PRODUCTION CAR DETAILS· Engine type: V6· Estimated horsepower: more than 300 horsepower· Estimated torque: more than 250 lb. ft.· Displacement: 3.8 liters· Block material: high pressure die cast aluminum· Cylinder head material: aluminum· Valvetrain: Dual Over Head Cam (DOHC)· Valve timing: continuous variable valve timing· Estimated 0-60 mph: under 6 seconds· Transmission type: 6-speed manual· Front brakes: Brembo, 340 mm disc, twin-piston calipers· Rear brakes: Brembo, 330 mm disc, twin-piston calipers· Limited slip differential
Bilder von der L.A. Auto Show:[BILD]1195080570[/BILD] [BILD]1195080572[/BILD] [BILD]1195080573[/BILD][BILD]1195080574[/BILD] [BILD]1195080575[/BILD] [BILD]1195080576[/BILD]Video: http://www.youtube.com/watch?v=0qaTC5ajJqENoch viel mehr Bilder:http://www.autoblog.com/photos/hyundai- ... genesisLA/
